Configuring the channel number for the particular optic module failed on the specified port. This could indicate the optic module in the port does not support the optical wavelength associated with the channel number requested for configuration.
Issue the "show dwdm channel-map port <p1>" command to determine the supported channels by the optic module.
Warning
Configuring operation failed for DWDM Channel %channelNumber% due to a channel mapping error.
| Name | Type |
| channelNumber | uInt |
| slotPort | SlotPort |
